It is currently Fri Jul 18, 2025 11:02 am
PostPosted: Tue Sep 25, 2007 5:59 am
Evan may be the best person to answer this question as he does mostly repairs but I appreciate all input...certainly if you have worked on one... It's a Martin DC-16GTE. Does this guitar have a bolt on neck?
It has a plate that appears to be glued to the block so i am thinking it may be a bolt on. The heel has actually come loose from the joint at the bottom, to the tune of 3/32...
ANY/All comments are  greatly appreciated.
PostPosted: Tue Sep 25, 2007 6:04 am
Yes, the 16 series has bolt on necks.
PostPosted: Tue Sep 25, 2007 6:20 am
I think only one bolt though, not two.
PostPosted: Tue Sep 25, 2007 6:51 am
Yes Dave but it is not a Taylor style. The bolt is used to help in the gluing by pulling the heel in tight. Don't get me started on this type of construction or I will make Grumpy look like a Disney movie.
Best, Evan
PostPosted: Tue Sep 25, 2007 8:26 am
Yes it is a single bolt...Thank YOU...Paul;Steve; and Evan!
Toughest part was getting the serial plate off without cracking it. Sort of awkward with the cutaway.
Anyway, All is well the neck came back into alignment once the screw was tightened. Everything went smooth...happy customer as I didn't charge for a neck re-set.
Again, THanks for the help!
PostPosted: Tue Sep 25, 2007 8:27 am
p.s. who's grumpy?
PostPosted: Tue Sep 25, 2007 8:32 am
Grumpy, AKA, Mario.
One bolt...don't forget the glue!
PostPosted: Tue Sep 25, 2007 8:35 am
So Mario is Grumpy...the things you guys come up with...I thought he was just pissed off!
PostPosted: Tue Sep 25, 2007 9:50 am
Single #3 phillips head screw, and the cover is only taped on.
Evan, I'm with you on this. I can go on (and often have) about what the
reasoning is behind this joint.
PostPosted: Tue Sep 25, 2007 10:08 am
Last Name: Garrish
[QUOTE=Dave-SKG] So Mario is Grumpy...the things you guys come up with...I thought he was just XXXXXXXX off![/QUOTE]
Five sets of BRW say that message is going to disappear...
Bob Garrish
PostPosted: Thu Sep 27, 2007 8:26 am
Dave:
I thought I should un-lurk here and share a concern with you. As Evan mentioned in his post the screw is there (according to Martin) only to hold the tenon tight while the glue dries. If you were able to tighten it and snug the heel up any at all, I'm concerned that the glue joint might have failed.
As you probably noticed, the guitar has a plywood neck block. What you probably couldn't notice is that there is only about 1/4" of unreinforced plywood between the head of the screw and the and the neck tenon. In other words, I think it's much too fragile of a connection to depend on the screw holding the neck in place. But maybe I worry too much and everything will be fine. If the guitar lives near you though, it might be a good idea to check on it a bit down the road.
As far as removing the screw cap, (yes it will break sometimes.... don't ask how I know that )I use a short, thin, 90 degree spatula. Before I made that, I just removed the 'barn door' electronics (4 small screws) and used a long spatula through that opening.
It sounds like Evan and I could rant for a while about this type of neck joint. While I like m&t joints, I think doing it the way they did put Martin about half way between a bolt-on and a glue joint. I wish they had taken a step or two more in either direction. I'd be bit happier anyway.
I've lurked around here for quite a while. I don't build them but I spend most of my days putting them back together. I've always been in awe of the folks that can take a few chunks of wood, carve it down to 5 or 6 pounds, and have it live under 175 lbs. of stress all it's life and still sound good. Many of the guitars I've seen pictured on this forum are some of the most beautiful ones I've ever seen.
Great work, great forum.
Jay
PostPosted: Thu Sep 27, 2007 10:12 am
Welcome aboard, Jay!
Sounds like you've got a well of experience of your own to draw from. Look forward to your input!
